TrailBlazer 2002-2009
2002 TB died and wont start
Old Feb 4, 2007 | 8:01 PM
kennige's Avatar
Default 2002 TB died and wont start
My 2002 trailblazer died nin the driveway and wont start or shift out of park. It was running fine when it started torun rough. The began fluctuating around 50 mph and then it died.All of the accessories work fine, but when you turn the key to start it nothing happens. The turn signals do not work and none of the gauges work. The shift indicator light is the only thing that come on. I found the release on the console to shift to nuetral so i could move it to the street for the wrecker, but i want to know if there is anything else i can do.
Thanks
Old Feb 8, 2007 | 1:05 AM
RonH's Avatar
Default RE: 2002 TB died and wont start
Have your checked you battery connection?
Old Feb 8, 2007 | 4:11 PM
rbarrios's Avatar
if its an AC delco battery- check the + terminal. been known to leak and eventually have the terminal break off or cause little power to get thru.....
Old Jul 24, 2008 | 2:00 PM
02trailblazeryyc's Avatar
I had the exact issue with my 2002 trailblazer. The problem was the ignition switch had to be replaced. I'm actually on my third ignition switch so i'm thinking this should be a recall, as I see this seems to be a common problem.
Steelman512
Apr 5, 2019 8:04 AM
aabner75
Feb 25, 2014 4:03 PM
kbest.1990
Feb 2, 2012 4:53 AM
shouldaboughtaford
Jul 20, 2011 7:37 PM
mason32
Apr 10, 2010 6:43 AM
