TrailBlazer 2002-2009
2003 Trailblazer 5.3 4wd
Old Dec 8, 2020 | 8:37 AM
Kmanning28's Avatar
Default 2003 Trailblazer 5.3 4wd
Speedometer doesnt register until about 20 mph and when it decels to about 20 mph it falls flat. Also does not shift properly until speedometer comes online. Have replace shift solenoids, cleaned and or replaced wheel speed sensors and tail shaft sensor. I know cluster is bad because the other gauges are messing up too. If I replaced ip cluster will that resolve the shifting issue? Thanks for any help
Old Dec 8, 2020 | 11:14 AM
Welcome from Florida. If you can solder, you can repair the cluster yourself. There was a problem with the stepper motors in GM cars from around 03 to 06. I used to have an 03 Trailblazer with a bad speedometer. I replaced the stepper motor for the speedometer and the other 5 gauges and the cluster worked great after that. I do not thin the shifting problem is related to the bad cluster. Unfortunately I also had the transmission go bad at just over 50,000 miles and had to have it rebuilt.
Little Bear
1988 - 1998 (GMT400)
11
May 24, 2020 4:44 PM
2763pig
May 25, 2015 8:24 AM
IREFUSE
Nov 7, 2014 9:59 AM
robertmack83
May 17, 2009 7:53 PM
hillbilleous
Apr 18, 2007 8:21 PM
