TrailBlazer 2002-2009
2005 Trailblazer cruise control
Old Jun 20, 2010 | 11:08 AM
mcff2721's Avatar
Unhappy 2005 Trailblazer cruise control
Hello everyone, hope someone can help me out. I have a 2005 Trailblazer that the cruise control stopped working on. It started acting up and would only work after i drove for awhile, shut it off and then restarted again. It has completely stopped working and I'm hoping I can get a fix for it before vacation in July(long roadtrip).
Old Jun 22, 2010 | 7:52 PM
Official GM Rep
Have you had your vehicle checked by a local dealership for this issue yet? I would suggest starting there as they would be able to fix it as well. I hope that helps.
Jeff Morris, GM Customer Service
Old Jun 22, 2010 | 9:37 PM
Bill's Dad's Avatar
sounds like a module control type issue to me maybe...You should see if you can gain access to a repair manual 1st to assist you if you want to self repair.
Old Jun 23, 2010 | 1:31 PM
rbarrios's Avatar
is your check engine light on? if it is on- some set codes will disable Cruise.
Any of your tailights burned out? I think Ive read that burned out lights can cause Cruise to not work (though this is iff).
Scan your car for pending codes- (this related to set codes).
Old Mar 8, 2011 | 11:56 PM
archebald23's Avatar
A good chevrolet trailblazer repair kit or manual would be very fitting in this one. I would rather get some good things there, rather than taking risk on fixing it on my own accord. Plus with the help of the people here, things would have been very much convenient in order to see some ways to solve it.
Old Apr 17, 2013 | 1:01 PM
PJinOH's Avatar
Default 2nd Fuse Block!
I understand that most the replies here are at best 3 yrs old. However, in my lengthy search I came upon this website when I couldn't understand why the brake lights in my '02 Trailblazer LS didn't work but my 3rd brake light did?!? I solve my issue after several days of searching for the answer when it turned out be so simple!
The '02 Trailblazer has a SECOND fuse block under the drivers side back seat. If you still have your manual, it will show you a diagram of it (mine is on page 6-61). There, unlike the fuse block under the hood, this one I.D.'s each fuse. Take a look at #34 15AMP "VEH STOP". Also know that this control's your Cruise Control. I'll bet it's blown?
Ii replaced this fuse and VOILA, ALL brake lights AND cruise control work again, good luck!!
Old Aug 6, 2019 | 2:48 AM
rsgolden's Avatar
i had gotten mine used and dealer said nothing about the tire release tools .. well in my search i came upon this { your} statement about the second fuse block well low and behold my fuse wasnt blown but you lead me to finding 4$ in change the lug wrench and the tire release tools
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
marilove
Oct 13, 2008 8:15 PM
kbridge234
Sep 4, 2008 10:03 AM
nolegirl10
Mar 8, 2007 10:37 PM
