TrailBlazer 2002-2009
4WD light on - dash switch and transfer case motor replaced but didn't help - no erro
Old Oct 26, 2023 | 4:26 PM
baskervi1's Avatar
Default 4WD light on - dash switch and transfer case motor replaced but didn't help - no erro
It's a 2004 Trailblazer with 4.2L.
The 4WD light is on the dash. Over the week, I've replaced the dash switch and transfer case motor, but the light is still on.
The engine light has been on for a while for two error codes, and both were for leaks in the EVAP system. One was PO455, but I don't recall the other - one was serious and the other I guess was a standard leak. I replaced the fuel cap last week, so there is currently no engine light. There was never a code for the 4WD.
I've not tried another TCCM. I've found one local, but I've read it has to be programmed. Dealer wants $200 plus fees, so probably around $250 after all is said and done. I've checked all connections and cables, and everything appears to be in order.
What would be the next best step to check?
Old Oct 26, 2023 | 6:36 PM
You'll need to scan the vehicle with a professional diagnostic tool to determine the fault that is triggering the 4WD light.
Then post it here and make sure you search the technical bulletins like these:
https://www.tsbsearch.com/GMC/05-04-21-003C
https://www.tsbsearch.com/Chevrolet/04-04-21-004
https://gmtnation.com/forums/threads...89/#post-24787
Old Oct 26, 2023 | 8:26 PM
baskervi1's Avatar
I have a consumer scan tool, and there is currently no check engine lights or faults reported. I presume you are saying that the professional diagnostic tool will provide details that are not showing up on the OBD2 port?
Old Oct 26, 2023 | 8:27 PM
baskervi1's Avatar
I'll post this anyway. We took it out for a drive tonight, and it dawned on me there are no lights showing for 2WD, which is where the switch is pointed. When I initially start up the car, they all light up, but then they all go away.
Old Oct 26, 2023 | 10:01 PM
baskervi1's Avatar
I've been looking into getting codes from the TCCM, and I see they are accessed differently. This will be an interesting challenge, but I program devices through serial equipment, so I'll see how far I get. Thanks
Old Oct 26, 2023 | 10:54 PM
Correct. Basic tools are unable to communicate with your Transfer Case Shift Control Module. (it's proprietary stuff, not legislated OBD)
Try swinging by an Autozone, Advance, OReily, etc.
Ed133
Apr 2, 2024 3:43 PM
karensue1
Feb 5, 2018 9:55 PM
stayathomedad
Sep 24, 2014 3:45 PM
hood974
Sep 26, 2011 11:35 PM
oltrout
Sep 24, 2009 6:52 PM
