TrailBlazer 2002-2009
Misfire cylinder 1
Old Feb 8, 2021 | 10:22 AM
Timothy.Johnson's Avatar
Default Misfire cylinder 1
I have a 2008 trailblazer showing a misfire on cylinder 1. I have replaced all spark plugs and coil packs and it’s still showing a misfire on cylinder 1. You can only feel it at idle and it’s hardly noticeable. Once you press the throttle the misfire goes away and the vehicle drives perfectly. I’ve changed the spark plug again and the treads have either oil or gas substance on them. But it’s only on the treads. The rest of the spark plug is clean, even the electrode is clean. When going down the road if you let off the throttle the rpm drops down then comes right back up. The vehicle drives and runs perfect other than those two issues. I am stumped on where to go to from here.
Old Feb 8, 2021 | 12:16 PM
kevinkpk's Avatar
I'd check the compression.
Old Feb 8, 2021 | 5:11 PM
try swapping the fuel injector into a different cylinder
dogman1313
Sep 22, 2014 10:22 AM
normagden
Jul 4, 2013 11:36 PM
unkindshadow35
Feb 2, 2013 10:50 PM
a_kraker99
Nov 6, 2012 9:25 AM
