TrailBlazer 2002-2009
Oil pressure not working
Old May 24, 2016 | 12:55 PM
kyle1252011's Avatar
Default Oil pressure not working
2005 tb 4.2. My oil pressure gauge isn't working I have already replaced the stepper motor and the sensor itself. Am I missing anything? Or is it a pcm malfunction? Thanks
Old May 25, 2016 | 8:01 AM
cleveland63b's Avatar
do you have good oil pressure? any engine noise?
Old May 25, 2016 | 9:35 AM
I have good pressure and and the engine sounds fine other that the misfire, but that just popped up this morning and I don't think its related
Old May 25, 2016 | 10:45 PM
Noticed this today... If I reset my pcm the gauge will either max out and then slowly die all the way to zero as I give it throttle. Or it will go to 40 and then slowly die to zero. Misfire was caused by a bad coil pack so engine sounds good and I have plenty of oil. I'm just worried my gauge it malfunctioning because of a poor connection between the gauge and pcm or that the printed circuited board is shot
Old May 26, 2016 | 11:13 AM
A relatively cheap and easy fix would be to put a mechanical oil pressure gauge in the car.
Old Mar 25, 2021 | 9:47 PM
hughjd's Avatar
Check oil pressure to insure you have pressure. Replace sending unit located just above oil filter. Most likely leaking oil, clean plug with solvent to get oil out or replace it. Voltage on this is bias and not direct so it can short with oil contamination.
Sassy Kat
Mar 17, 2021 11:49 AM
pnkansas
Apr 7, 2016 12:47 PM
privatecarp
Nov 30, 2014 4:56 PM
trx680
Aug 2, 2014 8:39 AM
Derl
Nov 12, 2012 12:11 PM
