Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2000 Chevy Express cranks but won't start.
Old Feb 17, 2020 | 8:29 PM
MelGlen1985's Avatar
Unhappy 2000 Chevy Express cranks but won't start.
Chevy Express 1500 5.7 liter cranks but won't start. It sounds like it could be going to fire but then it doesn't run.
I checked the fuel pump And it doesn't seem to be the problem.
Any help would be greatly appreciated.
I am totally stumped here.
Old Feb 17, 2020 | 10:53 PM
oilcanhenry's Avatar
Do you have any codes? Put a fuel pressure gauge on it and test the pump. and regulator. If not you likely have an ignition issue going on. Are you getting a good spark?
Old Feb 22, 2020 | 12:17 PM
Thank you for your reply. Any help is greatly appreciated.
Answer to question one: no codes
answer to question two: I tested the fuel pump gauge and it had over 60 PSI and dropped five psi in about 6 to 7 minutes.
answer to question three: I have spark on every cylinder
Old Feb 23, 2020 | 6:57 AM
Spray some gas into the throttle body. If it runs for a few seconds then you have a fuel issue, Possibly clogged injectors.
Old Feb 23, 2020 | 12:04 PM
I have found that I have spark continuously at one of my plugs or maybe more than one.
do you know why I would have spark continuously at one of the plugs?
i’m going to try this first and then I will try to bring the gas in to the throttlebody.
Old Feb 23, 2020 | 3:29 PM
You posted in the Chevy Traverse section, so first of all I'd recommend posting in the right place where other Express owners see your question and give you relevant answers.
I wouldn't be concerned about waste spark. Fuel injection was a problem in those years, so I would follow oldchevy's suggestion.
Old Feb 23, 2020 | 4:53 PM
Sorry I posted in wrong place. Not very computer savvy. I barely got anything posted at all.
I did read however on the rules that if I post on two different sites, that my info can be deleted altogether.
Old Feb 23, 2020 | 8:15 PM
Which computer skill does a person need for reading?
Old Feb 23, 2020 | 11:09 PM
Help if you wud like sir,
don’t help if you like.
You can easily pass over my posts and read the ones that you want to read.
it shouldn’t bother you that much.Bye to you
Old Feb 24, 2020 | 9:42 PM
I tried to help. I didn't have to take time out of my day to give you that forum tip.
We suggested the next troubleshooting step. Ball is in your court.
