Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
2000 Chevy Express cranks but won't start.
Old Mar 3, 2020 | 1:58 PM
  #11
MelGlen1985's Avatar
I sprayed some gas into the throttlebody and it didn’t start. I do have spark though
Old Mar 3, 2020 | 5:36 PM
  #12
I also replaced Crank position sensor,
map sensor, ignition control module.
I replaced The battery because the old one did have a bad cell.
I checked the distributor and it appear to be OK.
I rotated the engine so that number one cylinder is at TDC, then checked the distributor and it is pointing to number one.
When I try to start the vehicle it appears to backfire through the intake.
Old Nov 24, 2020 | 12:44 AM
  #13
Ayinla Mumeen's Avatar
Default Fault
My Chevrolet 2500 crank but seems to be not spark.
Old Nov 24, 2020 | 3:22 AM
  #14
check fuses
Old Nov 26, 2020 | 7:58 PM
  #15
chevyboy@22's Avatar
Did you check voltage on pink wire at ignition coil module? Use a test light and check with engine cranking. That circuit is fuse protected, the fuse is in underhood fuse box, ign/inj fuse.
artimious7
Dec 15, 2020 5:10 PM
jeff739
Jan 19, 2020 9:40 AM
Le_Lama
Dec 23, 2019 9:27 PM
ekyoo
May 12, 2012 6:27 PM
BuyOuts
Nov 10, 2009 8:16 AM
