Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
key in ignition, open door, no chime
Old Feb 10, 2012 | 1:52 PM
countrybea50's Avatar
Default key in ignition, open door, no chime
Noticed no chime when I open door and keys are in ignition the next day after I brought home my brand new 2012 Chevy Traverse; thought it was a setting on the lock/unlock features but can't figure it out.
Old Feb 10, 2012 | 3:34 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> countrybea50,
The door ajar message displays and a chime sounds if the passenger door is not fully closed and the vehicle is shifted out of park.
Was the vehicle in park when you opened the door? Does the chime sound when the hood, liftgate, rear or passenger doors are open?
If the chime sounds for the others, but not for the driver door, it may be a switch. This is not a diagnosis, just a suggestion. I encourage you to take the vehicle in for a quick inspection.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Feb 15, 2012 | 1:08 PM
rbarrios's Avatar
could be a bad door switch.
With engine running- in park or drive...
open the door- you should get a message on the DIC- that says your door is open/with ding ding ding
if you dont get the message- then try the other doors...
but if your door doesnt- its most likely the door switch.
xrayrep
Jun 21, 2014 4:59 PM
wopp
Jul 13, 2009 4:34 PM
sketch222
Jun 18, 2009 8:18 PM
daddyrabbut
Mar 8, 2009 10:04 PM
rickford48
Sep 25, 2008 3:14 PM
