Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
P0297 code
Old Jan 12, 2014 | 2:45 PM
mk1264's Avatar
Default P0297 code
Anybody get this code? How do I get rid of it?
Old Jan 12, 2014 | 7:45 PM
IIRC there is a tsb to check for exhaust leaks at the cat gaskets; which creates air leaks into the exhaust that can cause false lean conditions for the o2 sensors.
Old Jan 13, 2014 | 9:14 AM
mk1264's Avatar
It says a rich condition occurred. Could my o2 sensors be cause? They are brand new.
Old Jan 13, 2014 | 9:30 PM
nope!
Old Jan 13, 2014 | 9:58 PM
the false air in the exhaust leans out what the 02 are reading. the ecm tries to correct this and richens the mixture. This sets the p2097 which is a dtc for rich correction limit.
You probably have an exhaust leak!
tsb #PIP4964B
Old Jan 14, 2014 | 6:19 PM
mk1264's Avatar
Well this is what I found. It is the piece of flex pipe right behind the last O2 sensor. My wife hit a ladder about a year and a half ago and it tore a section of the steel braid but I couldn't tell if it broke the pipe. But it is a tiny pin hole. I can't tell if anymore is damaged. Hope that is what is causing the code!
Attached Thumbnails P0297 code-forumrunner_20140114_191529.jpg   P0297 code-forumrunner_20140114_191545.jpg   P0297 code-forumrunner_20140114_191559.jpg
Old Jan 15, 2014 | 5:12 PM
mk1264's Avatar
Well the P2097 code is not there but s P0008 now.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
timT
Nov 21, 2011 10:29 PM
T'boo Ted
Oct 28, 2010 5:15 PM
tshunt01
Feb 19, 2007 12:26 AM
