Uplander 2005-2009
Platform: U-Body
2008 AC condenser leaking into wheel well
Old Jul 2, 2013 | 6:56 PM
442dude's Avatar
Default 2008 AC condenser leaking into wheel well
Hello -
Wanted to provide an update and hopefully help someone with the same problem...
Last year the driver's side wheel well was holding water...we determined it was from the AC condenser not draining outside the vehicle. The dealer cleaned the drain tube and all was well...for a while
This year, same problem, wet carpet from the AC condenser...nothing was draining. With the help of a friend we finally figured it out:
The drain in the firewall was letting the water out but it was flowing right back into the passenger department. It would drip out and then follow the tube right back into the car. To fix it we put a small rubber elbow on the end of it to get the water away from the firewall. No more wet carpet - water drains safely out through the elbow now instead of back into the car.
The small rubber elbow we used was actually a spark plug boot that fit perfectly onto the drain. Cheap fix...problem solved.
Hope this helps someone out.
Old Jul 2, 2013 | 10:29 PM
Papa Bear's Avatar
Excellent !!
Old May 1, 2014 | 2:48 AM
yjf1535's Avatar
I had the same problem with my 2008 Uplander. I read this on a forum somewhere but can't remember where. I took a small amount of silicone (RTV) and wiped it around the discharge tube and grommet making sure not to get any on the inside of the tube. It worked like a charm.
82LiftedChevy
Sep 25, 2013 8:50 PM
MyBowTieGuy
Sep 2, 2011 6:59 PM
lumina_guy
Apr 27, 2011 11:34 PM
Makkybarr
Jul 13, 2010 10:39 AM
