2008 Uplander: Fan speed control only works at dial 5
Fan speed control only works at dial 5 (2008 uplander), but not at speed of 1-4. It appears motor blower resistor is broken and needs to be replaced. Where is location of fan speed control motor blower resistor? Thank you for your any inormation.
You are correct to suspect the blower resistor...cheap part so its a good place to start.
Blower resistor located on firewall- passenger side footwell. Its really tucked up there so you'll have to contort yourself to get to it.
Alnascar97
Uplander
February 20th, 2011 11:02 AM
