Uplander 2005-2009
Platform: U-Body
ABS C:0035,0036,0037,0040,0220 Repair Procedure
Old Oct 18, 2021 | 9:17 PM
Yoshi99's Avatar
Default ABS C:0035,0036,0037,0040,0220 Repair Procedure
2007 Uplander
This uplander presents with ABS Codes C:0035,0036,0037,0040,0220
This vehicle needs:
1 a full brake job front + rear, @ new F/R rotors / Calipers
2 Front Control arms
3 TWO Front Left & right Hubs
Would you recommend replacing the bearing hubs first?
Or Would you recommend replacing the lower control arm assemblies first before the bearing hubs and brake work?
The bearings are original and should be changed to assure good ABS sensors up front on both sides. Possibly the wiring harness may need replacement.
Your thoughts would be appreciated!
Thanks
mark121268
Feb 26, 2012 12:39 AM
martygreen
Jan 4, 2012 8:40 AM
ericmckinney
Uplander
Jul 21, 2011 4:04 PM
RobertInCypress
Feb 17, 2010 6:32 PM
Z24buzz7
Oct 8, 2008 10:09 PM
