Uplander 2005-2009
Platform: U-Body
Air Conditioner & Locks
Old May 20, 2012 | 5:50 PM
mmd's Avatar
mmd
Default Air Conditioner & Locks
Looking for suggestions at what may be wrong with my 2005 Uplander. Two different problems:
Air Conditioner doesn't work. The air that flows out seems to be the same air temperature as the non air conditioner. If it is warm out side, warm air will blow. The AC Control Head was replaced after Christmas.
The power doors won't lock. Locking them with the flob doesn't work. Locking the doors with the door buttons doesn't work.
Any suggestions?
Old May 20, 2012 | 6:56 PM
Of course the old standard. Did you check the fuses? Look at the compressor and see if the clutch is engaged and stays engaged. Not going on and off. Do you hear a click when you try and lock the doors? You don't say, but do they unlock? Fuses first!
Old May 21, 2012 | 9:38 AM
johntaps's Avatar
Former Sponsor
Post Air Conditioner & Locks
Have you checked for the refrigerant leak? I think it might be the problem. Check the fuse and door window regulator for the power door.
Old May 21, 2012 | 11:44 AM
mmd's Avatar
mmd
When the power lock button to lock the door is press, there is a tiny click in the dash area. Both the flob and door button can unlock the doors.
Check the fuses, they seem fine.
What would be the signs of a refrigerant leak?
After replacing the AC Control Head, the computer wasn't flashed. Could this be the problem for the air conditioning not working?
Old May 21, 2012 | 1:13 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> mmd,
The others have posted some great possibilities regarding the AC. The door locks may be due to an actuator issue.
I encourage you to have the vehicle inspected by a certified technician for additional information.
Louis
GM Customer Service
adigitaldj1
Uplander
Jun 19, 2014 9:15 PM
sbh111
Aug 31, 2007 10:18 PM
Dangrousdave20
Apr 28, 2007 2:35 PM
Southland
Feb 28, 2007 1:13 PM
