Uplander 2005-2009
Platform: U-Body
Old Jul 22, 2015, 12:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Blend door actuator ?
Old Feb 5, 2009 | 6:02 PM
JoeCB's Avatar
Thumbs down Blend door actuator ?
When it gets real cold I get sometimes only get cold air. I think that the blend door is sticking or the actuator is going bad. I almost afraid to ask ! but how do you get to the blend door and actuator?
Thanks
Joe B
Old Feb 6, 2009 | 9:55 PM
shawnvw's Avatar
Banned
what year? single zone or dual zone? Are both of the heater hoses hot?
Old Feb 9, 2009 | 6:06 PM
JoeCB's Avatar
OOPs, sorry, forgot that important info... the Uplander is a 2005 with single zone heater. The heater is back to working fine. The only time I seem to have a problem is when it gets real cold, like the other day when it got down to zero... then It's blowing only outside air. Since it works OK otherwise i'm thinking that the actuator is OK and the problem is that when real cold the housing ( plastic I guess?) shrinks and binds the blend door. In any case I need to get in there and check it out.
Joe B
Old Feb 9, 2009 | 10:26 PM
shawnvw's Avatar
Banned
Temperature Valve Actuator Replacement (Single Zone)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1536779&pubCellSyskey=63237&p ubObjSyskey=1536779&from=sm&laborOpCode=&cellId=63 237#ss1-1536779">Removal Procedure
  1. [*]
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1536779&pubCellSyskey=63237&p ubObjSyskey=1536779&from=sm&laborOpCode=&cellId=63 237#ss2-1536779">Installation Procedure
  1. [*]
Old Feb 9, 2009 | 10:27 PM
shawnvw's Avatar
Banned
Actuator Recalibration
When replacing the HVAC control module, it will be necessary to allow the HVAC control module to perform a calibration process.
When installing the HVAC control module, be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted,
improper HVAC performance will result.
  1. Place the ignition switch to the OFF position.
  2. Disconnect the scan tool.
  3. Install the HVAC control module.
  4. Connect all previously disconnected components.
  5. Start the vehicle.
  6. Wait 40 seconds for the HVAC control module to self-calibrate.
  7. Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process.
When installing the HVAC actuator be sure to perform one of the following:
interrupted, improper HVAC performance will result.
Preferred Method (w/Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch in the OFF position.
  3. Install the HVAC actuator.
  6. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
  1. Clear all DTCs.
  2. Place the ignition switch to the OFF position.
  3. Connect all previously disconnected components.
  4. With the Mode **** in the PANEL position, press and hold the AC button for 5 seconds.
  5. Rotate the Mode **** fully counterclockwise.
  6. Rotate the Mode **** fully clockwise.
  7. Rotate the Mode **** fully counterclockwise.
  8. Release the AC button.
  9. Wait 40 seconds for the HVAC control module to self-calibrate.
  10. Start the vehicle.
  11. Verify that no DTCs have set as current DTCs.
Old Feb 10, 2009 | 4:05 PM
JoeCB's Avatar
Shawn, thank you very much...
Joe B
Old Feb 10, 2009 | 7:50 PM
shawnvw's Avatar
Banned
good luck!
Old Apr 6, 2009 | 7:23 PM
scrnchr's Avatar
Hello, would a 2004 Chevy Tahoe use this same HVAC control module calibration?
Clear all DTCs.
Start the vehicle.
Old Aug 11, 2009 | 6:17 PM
bk7716's Avatar
Default 2001 Buick Regal
Any pointers on installing a replacement Air Door Actuator on a 2001 Buick Regal with Dual Zone cliamte control? I am currently getting Cold air on the Driver's side and hot air on the passengers.
Thanks
Old Oct 5, 2009 | 8:51 AM
stikkyd's Avatar
Default heat not working
air conditioner works fine but, heat wont come on. blows cool air out when on heater. coolant level is fine and no leaks in car like the heater core is broke so wondering what problem could be. Thanks.
