Can The Door warning be deactivated?
I have a warning door chime staying one every so often,usually when I least expect it. The driver sliding doors causes it,but the pass does at time as well. I've looked at the switch's at the door and clean them,but still get the chime when I least expect it. Especially if i use the door in the electric mode.
Is there a way to deactivate the chime? I hate when it happens and i have to drive with the warning on. Drives me nuts.
For those whom have wonder and or are having sliding door warning issues. i found a wiring schamatic and it seems everything is control throught the sliding doors control modules. I disconnected the modules and warning chime has stop. Even with doors open and in drive.
The cons is that your power sliding door will no longer work,they will be manual which is fine with me since I have a bad drivers side motor anyway. At least i don't have to worry about the darn chime going off. Did i mention i drove 80 miles with the chime,chimming?
brjl
Nov 16, 2014 7:55 AM
MikeA
Aug 23, 2011 8:20 PM
