Uplander 2005-2009
Platform: U-Body
Chevy Uplander 2008 Computer Rest
Old Aug 9, 2012 | 12:27 PM
Sandra's Avatar
Default Chevy Uplander 2008 Computer Rest
Hi ,
I have a chevy uplander 2008 LT, the hub assembly went wrong had the play in it bad bearings. ABS and TCS Light start blinking and went solid. so we replace it and after replacing its still solid, I am guessing computer need to be rest and is there a way to reset the computer . or how to reset the lights
Sandra
Old Aug 9, 2012 | 1:59 PM
kevinkpk's Avatar
Unhook the battery ground for an hour or so, then hook it back up.
Old Aug 9, 2012 | 9:19 PM
MDTAHOE's Avatar
Professional Mechanic
Abs light will go out on its own if the problem is fixed. Depending on how it failed the light will go out as soon as you start it or within a few hundred feet of motion. I you drove it and it did not go out it is not fixed.
Old Aug 10, 2012 | 11:42 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Sandra,
Were you able to get this resolved?
Louis
GM Customer Service
Old May 20, 2017 | 5:32 PM
MrsTurner50's Avatar
Default Reset Computer????
I have a 2008 Chevy Uplander I disconnected the battery, Disconnected the Capacitor, Pulled all the fuses and it still Remembers Everything it will not reset WTF Please Help Me what am i missing????
Old Dec 10, 2022 | 2:11 PM
yzoldowltoo's Avatar
We had to pull the fuse on the ABS. It kept running even with the ignition off, and got red hot.
RJK
Apr 21, 2014 8:15 PM
Chevrolet Forum News
Nov 4, 2013 11:38 AM
fscoles
Uplander
Aug 22, 2011 9:04 PM
kylbra
Uplander
Aug 15, 2010 10:49 PM
cooper
May 27, 2007 10:08 PM
