Uplander 2005-2009
Platform: U-Body
ELM 327 Interface
Old Oct 12, 2015 | 11:16 PM
Patriot's Avatar
Default ELM 327 Interface
I just bought this OBD reader and download the apps, it works to other vehicles to name a few like ford fiesta, 2004 honda civic. But when i try to 2006 Uplander the response is nothing...any thought or advice will greatly appreciated..
Old Oct 13, 2015 | 6:20 AM
Papa Bear's Avatar
Try another reader on your Uplander.
Old Oct 14, 2015 | 8:40 PM
U.Nanimous's Avatar
+1 Papa Bear
If you don't have another one, go to AutoZone or similar and have them try to read your codes.
The Elm327 is bluetooth...can you at least tell if it is powering up in the Uplander?
Old Oct 14, 2015 | 9:18 PM
check pin 16 of the dlc connector for power
Old Oct 15, 2015 | 11:44 AM
Patriot's Avatar
Default Elm 327
Thanks for response guys...My uplander has only 4 pins connected and has power on one of the pins. Communications from ELM 327 is the problem..Maybe this ELM thing is not compatible to my Uplander.
Old Oct 15, 2015 | 8:08 PM
that connector is not the dlc (diagnostic link connector). google obd II dlc and you will see what you should be connecting to.
Old Oct 16, 2015 | 10:14 PM
I took a second look at your photo. that is a 16 pin dlc but I did not recognize it from the back side. all the pin out will not be filled. you can see the pin numbers cast in plastic. You will have pins 16 which power the scan tool. grd will be provided from pins 4 and 5. depending of the communication protocol that the vehicle uses will determine which pins are used for data transfer.
I am not sure if the 06 uses CAN BUS communication. If may be class 2
Old Oct 17, 2015 | 11:43 AM
Patriot's Avatar
Thanks Tech 2 for response...i just insert the OBDII (the real meter that you can buy at any auto stores) in there and it reads lot of information. I dont know why only 4 wires on it. Just want to share that ELM 327 with bluetooth is not compatible with my 06.
Old Oct 17, 2015 | 2:43 PM
Papa Bear's Avatar
Is your ELM327 device a Chinese clone or the real McCoy ??
Old Oct 19, 2015 | 12:04 PM
Patriot's Avatar
I beleive its made from China..LongGang Shenzhen China...
