Uplander 2005-2009
Platform: U-Body
Heated seats out on driver side...
Old Oct 22, 2012 | 8:18 PM
coolzzy's Avatar
Default Heated seats out on driver side...
Driver Side seat doesn't work but I do hear the relay under the seat click when I turn them on and off. Does this mean the seat heater pads (back and bottom) are done for? Any idea how hard they would be to replace? Winter is nearly here and that drivers seat gets more use than any other, would be nice to have heat...
Old Oct 24, 2012 | 8:58 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> coolzzy,
Which vehicle are you referring to? You posted in the 2005-2009 Uplander thread, but your profile states your vehicles as: 2007 Saturn Relay 3, 2007 Chevy HHR LT & 2006 Chevy Trailblazer. Which vehicle are you referring to?
Louis
GM Customer Service
Old Oct 25, 2012 | 8:31 AM
coolzzy's Avatar
Louis
GM Customer Service
I am referring to my 2007 Saturn relay, which is mechanically the same as a Chevy Uplander.
Old Oct 26, 2012 | 12:15 PM
Official GM Rep
Have you checked the #13 (heated seats) and #31 (power seats) fuses in the Instrument Panel Fuse Block?
If the issue persists, consider having the vehicle inspected by a certified technician for an official diagnosis.
Please keep us posted.
Louis
GM Customer Service
Old Oct 27, 2012 | 11:20 AM
coolzzy's Avatar
Louis
GM Customer Service
Yes, all fuses are good. The power seats work fine on both sides and heater is good on passenger side, just not drivers side. Relay under drivers seat clicks when seat heater button is pressed and button stays lit but no heat.
Old Oct 28, 2012 | 5:49 PM
raybo100's Avatar
I would jumper the relay to see if the seat heats up, if so there you go, if not the problem probably in the seat itself Jumper as close to the element as possible
Old Oct 30, 2012 | 10:19 PM
coolzzy's Avatar
What wires do I jumper, or are there only 2 coming out of the relay?
Old Feb 6, 2013 | 8:03 PM
Lorna Olney Schutz's Avatar
We have a 2005 Uplander van and our driver's side seat no longer heats up but the rider's side does. Is there a fix?
Old May 13, 2014 | 11:21 AM
AGUNDN's Avatar
Sorry to drag up an old thread, but I am putting in heaters but can't get the hard plastic pieces off the back of the drivers seat. Any helpful info?
fishin-frog
32
Mar 9, 2025 10:02 PM
1969bnking
Dec 4, 2022 10:08 PM
clayman
Apr 19, 2009 7:55 PM
