Uplander 2005-2009
Platform: U-Body
Iridium Vs. Platinum
Old Jul 5, 2013 | 1:08 PM
Patriot's Avatar
Default Iridium Vs. Platinum
Which spark plugs is best for Uplander 2006 (Iridium or Platinum). If the idling is normal, How can you tell if you need to replace these parts?
Old Jul 5, 2013 | 2:29 PM
Papa Bear's Avatar
I'd use the AA Delco 41-101 plug at 100,000 miles as recommended.
Old Jul 5, 2013 | 9:32 PM
Patriot's Avatar
Thanks papa bear...i prefered to use regular gas as well coz it cheaper, does it affect the performance if i use the Delco 41-101?
Old Jul 6, 2013 | 9:07 AM
Papa Bear's Avatar
I believe that 41-101 is what came in the vehicle from the factory. What plug number is recommended in the owner's manual? Call your local GM dealer parts dept. and ask what they use as original equipment replacement.
Also, regular grade gas is what is recommended. Anything more would likely be a waste of money.
Old Jul 6, 2013 | 9:15 AM
The factory platinum plugs gave me 100,000 miles and when they were changed, they looked almost as good as the new ones. Why mess with success?
Old Jul 7, 2013 | 8:27 AM
Patriot's Avatar
Thanks for the 2 guys out there for giving their own experienced and their opinion about spark plugs...(PPB and OC). I also read on page 6 about the discussion on SP and the manual says 41-101 for 3.5 engines is recomended.
Old Jul 7, 2013 | 9:48 AM
Well said and pretty much sums it all up...
For What Its Worth... my 07 Tahoe uses the exact same factory spark plug that is used in the Corvette...
warthogcrewchief
Nov 13, 2013 4:06 PM
texasflyfisher
Sep 25, 2010 2:02 PM
Scootertrash
Dec 12, 2008 8:27 AM
dbrog28301
Colorado
May 21, 2007 9:48 PM
