Uplander 2005-2009
Platform: U-Body
Radiator Cap Leaking
Old Apr 10, 2024 | 12:21 PM
haze5736's Avatar
Default Radiator Cap Leaking
I seem to have a leak at the radiator cap. It's not a big leak just some seepage where the cap meets the tube going to the thermostat housing. I did notice one small drip onto the drive belt a couple of times after a drive. I replaced the cap with an OEM cap from the dealer and it is still happening. I'm not sure what else to check. I don't see any cracks in the tube that the cap screws into. But maybe I'm just not seeing it? Has anyone else seen this problem?
Old Apr 10, 2024 | 2:11 PM
It might not be a crack. It could be the surface is bent and not allowing a good seal.
Old Apr 10, 2024 | 3:36 PM
Please post your vehicle info, and a photo of your radiator neck would be really helpful here.
Old Apr 11, 2024 | 5:09 AM
haze5736's Avatar
It's a 2008 3.9l. I don't have a picture and it will be a while before I can get one.
Old Apr 12, 2024 | 2:34 PM
haze5736's Avatar
I just drove this car from New York to Florida and now there is not a trace of coolant seeping.
Old Apr 12, 2024 | 2:37 PM
guess it was loose
Old Jun 9, 2024 | 10:37 AM
04colyZQ8's Avatar
Mine does the same thing intermittently even after a new cap, fine for weeks then big puddle under passenger side control arm, next day dry very strange I’ll try a new neck
Old Jun 11, 2024 | 1:20 PM
haze5736's Avatar
I have not checked mine in a while thinking it somehow resolved itself. I guess I should get out there and have a look. The weird thing is that it leaked then stopped without me touching it in between. Cars don't tend to fix themselves. Whatever the problem is, it seems you and I are either making the same mistake or there is some underlying problem.
tommywass
Sep 4, 2018 10:42 AM
Devistator16
1988 - 1998 (GMT400)
Aug 23, 2017 10:15 PM
Nakeem Forte
Apr 3, 2017 9:22 PM
a1handy
Oct 18, 2014 8:55 AM
