Uplander 2005-2009
Platform: U-Body
Radio wont turn off and dome light won't come on when driver's door opened
Old Oct 17, 2014 | 6:22 PM
gneville's Avatar
Default Radio wont turn off and dome light won't come on when driver's door opened
My dome light won't turn on when I open drivers door. Works fine from passenger door. Also radio won't turn off when driver's door opened. works fine with passenger door. Suspect a bad door switch but can't locate it. Computer system knows when driver door is opened. Any Ideas?
Old Oct 20, 2014 | 10:11 PM
Official GM Rep
We're sorry to hear of these difficulties, gneville. We are not certified technicians and we're unable to provide technical advice, but we'd be happy to look further into your concerns. Feel free to send us a private message with your full contact information, VIN, current mileage, and dealership name. We look forward to hearing from you soon!
Kristen A.
Chevrolet Customer Care
Old Oct 21, 2014 | 7:40 AM
The door switch is usually located in the door lock mechanism, you will most likely need to remove the door panel to get access to it...
Old Oct 21, 2014 | 10:29 AM
gneville's Avatar
Thanks for the info. I located it and resolved the problem.
Old Oct 21, 2014 | 12:05 PM
What did the problem turn out to be?
Old Oct 22, 2014 | 5:03 PM
gneville's Avatar
The problem was the grease in the door latch mechanism. It was old and had gotten stiff. Thus the switch would not fully engage when the handle was pulled. if you pushed it to its full open position the light would come on. A little light oil loosened up the grease and it works great.
Old Oct 22, 2014 | 5:15 PM
Papa Bear's Avatar
Thank you for the follow-up.
It is very important for the members to find out what brought things to a satisfactory conclusion.
Well done !
Old Jan 22, 2021 | 3:05 PM
Rachel Lea Falgout's Avatar
How did you resolve your door switch problem?
Old Jan 31, 2021 | 5:13 PM
maddog0324's Avatar
See post #6.
Old Jun 4, 2022 | 1:26 PM
Yojimbo's Avatar
Newly Registered
how did you resolve this problem? I have the same issue in an 09'
