Uplander 2005-2009
Platform: U-Body
Radio wont turn off and dome light won't come on when driver's door opened
Old Sep 24, 2023 | 12:36 AM
  #11
John Jay's Avatar
Originally Posted by gneville
My dome light won't turn on when I open drivers door. Works fine from passenger door. Also radio won't turn off when driver's door opened. works fine with passenger door. Suspect a bad door switch but can't locate it. Computer system knows when driver door is opened. Any Ideas?
I drive a 2008 Isuzu I-290 pickup which is nearly identical to the Colorado. Having the same issue with the radio not turning off and the dome light not turning off when the driver door is opened.
Passenger side turns it off. I've checked the fuses and used a volt meter on the door jam switches. I even swapped the passenger side door jam switch to the driver side.
The volt meter shows 12 volts on the passenger side. It reads no power on the driver side door jam switch.
I took the door panel off just to verify there's no door latch switch. Ive looked at wiring diagrams the best I can.
highlander
Jun 22, 2021 11:21 AM
Roberto Puentes
May 31, 2020 7:37 AM
gneville
Uplander
Oct 17, 2014 7:21 PM
DSHACK13
Colorado
Apr 27, 2014 12:16 AM
Rags76USF
Nov 3, 2009 6:29 AM
