Uplander 2005-2009
Platform: U-Body
Rob
Old Jun 27, 2014 | 6:58 PM
toskala112's Avatar
Default Rob
I own a 2007 Chevy Uplander LT....the low oil pressure warning just started dinging at me today....I just had my oil changed not even 500-1000k ago....this is just yet another problem I have had with this vehicle has just been one thing after another seriously debating just dumping this vehicle only has 146,000 thousand on it I have had to sink almost as much money into it as what I paid for it anybody have any ideas what it may be?
Old Jun 27, 2014 | 11:25 PM
Val D.'s Avatar
Check the oil level first. I found many oil change shops have incorrect oil capacity data in their computers for the 3.5L engine. If they put 3.8L the oil level is always low. I put a sticker 4.2L next to the oil cap and have no more issues. And don't drive the car with low oil pressure warning, have it checked asap.
Old Jun 28, 2014 | 6:21 AM
Papa Bear's Avatar
It could be anything. Have the van checked and see what's wrong. Don't automatically blame the van .. it could be the person who changed the oil last time or perhaps the oil filter leaked.
Get all the facts then fix the fault.
Be sure to post here what you found.
Good luck.
Old Jun 28, 2014 | 12:04 PM
toskala112's Avatar
Default low oil pressure 2007 Uplander
Uplander went into the shop this morning oil level was full oil filter was ok pressure switch was fine...drove the vehicle to the shop warning light did not come on driving there drove for about 30-45 minutes after they couldnt find anything wrong with it low oil pressure displayed on dash and oil can icon appeared for a few seconds then turned off....just drove the vehicle 25-30 k at highway speeds and nothing no low oil pressure display or anything...any ideas? Confused on whats going on with it no visible or audible/physical warning signs vehicle is otherwise running very well....
Old Jun 28, 2014 | 3:07 PM
Papa Bear's Avatar
Did you take the van to the same people who changed the oil?
Did you take it to the dealer? How did they check the pressure switch to say it's "fine" ?
Does the oil light come on while you are driving or only when idling?
What brand of oil was put into the van? What viscosity? What make of oil filter?
How long have you owned the van?
Old Jun 28, 2014 | 7:05 PM
toskala112's Avatar
I did take it where the oil change was done....not sure how they checked the switch they just said it was operating the way it should.the icon comes on while driving just for a few seconds then shuts off.And I believe it was 5W30 Mobil one that was put in...
Old Jun 28, 2014 | 7:08 PM
toskala112's Avatar
I believe its a motomaster filter not sure...and I have owned the van for 3 1/2 years now....I have had heat issues with the van up until when the cross over gaskets were replaced this past winter....
Old Jun 28, 2014 | 7:42 PM
Papa Bear's Avatar
Geez, I wish all this info was in 1 thread !!
Did Canadian Tire do the oil change? Did a Canadian tire tech diagnose the switch?
Old Jun 28, 2014 | 8:18 PM
toskala112's Avatar
Sorry..yes it was cdn tire that did the oil change and diagnosed the switch
Old Jun 28, 2014 | 8:20 PM
toskala112's Avatar
They said if the icon comes on again it could be a problem with the switch but who really knows for sure....
