Uplander 2005-2009
Platform: U-Body
Slow coolant leak - suspect coolant crossover pipe gaskets - need pics and details
Old Mar 26, 2020 | 7:58 PM
  #11
12three's Avatar
smear the oil on bright white paper or towel. Transmission fluid is reddish.
the oil or trans fluid is mixed with the dexcool in this case... theres 'oil/trans fluid mixed coolant' floating inside the coolant overflow tank... and the cooling system had some rust... and i used lucas super coolant in there as well, which is blue and turns dexcool a bit darker, almost like an orange-red... paper towel wont give me an answer i dont think... both concoctions will be 'chocolate milk' i believe...
Old Mar 26, 2020 | 8:15 PM
  #12
you said it was floating so I thought you would be able to separate it.
Anyhow, pop the transmission lines off the radiator and blow some compressed air in there. See if any bubbles come up. Not too much pressure mind you.
You should also take a sample of the ATF to see if it's milky.
Old Mar 26, 2020 | 8:49 PM
  #13
12three's Avatar
yeah it rises to the top but it was chocolate milk-like when i first noticed it.
oil and tranny fluid both look normal.
i am going to plumb up the new tranny cooler and just bypass the oem one... with the coolant hitting 220F its too hot for the tranny 'cooler' anyways in my opinion...
Old Mar 26, 2020 | 9:07 PM
  #14
oil in coolant is bad but coolant going into the trans is death to a transmission. its impossible to flush out. water wrecks friction material clutch packs.
Giovanni Ruiz
Jun 13, 2018 8:09 AM
coachmendave
Mar 13, 2017 11:04 AM
gschroeder
Oct 14, 2013 1:29 PM
2001 2500
13
Feb 19, 2008 12:13 PM
ffdaryl
Mar 1, 2007 2:52 AM
