Sudn Oil Consumption
What would cause a sudden oil consumption increase? The van runs fine and is not leaking it on on the ground. I sometime smell oil burning slightly when stopped, but not all the time.
I can't find a PCV valve when I look at parts stores online.
2007 Uplander 3.9L
2007 Uplander 3.9L
I think there is some information missing here .....
Have you owned the van since new?
How many miles are on the van?
When did you notice this problem beginning?
Did you change the oil last time or did a shop do it?
What oil & filter are you using?
Do you do your own service (a DIY'er) of does a mechanic do your work?
How many miles are on the van? 159,000
When did you notice this problem beginning? this oil change
Did you change the oil last time or did a shop do it? I did
What oil & filter are you using? Valvoline 5w30 synthetic
Do you do your own service (a DIY'er) of does a mechanic do your work? own mostly
