Venture 1997-2005
Platform: U-Body
1997 venture turn signal not working
Old Jun 30, 2008 | 3:50 PM
whalen77's Avatar
Default 1997 venture turn signal not working
The left turn signal is not working. I have replaced the bulbs, but that didn't help. The dash turn signal light indicator blinks rapidly, so I suspect an electrical problem. Any areas I can look at myself so I don't have topay a repair shop to look at it? Any help is appreciated. Thanks!
Old Jan 11, 2009 | 4:39 PM
hazer396's Avatar
Default RE: 1997 venture turn signal not working
CHECK THY FUSE
Old Jan 15, 2009 | 9:59 PM
MDTAHOE's Avatar
Professional Mechanic
Replace the socket
Old Jan 30, 2009 | 4:48 PM
grejohn's Avatar
hi, how did you fixed your problem?? is it the fuse or the socket?? i have the same problem. thanks.
Old Feb 2, 2009 | 12:14 PM
dorman68's Avatar
Check your tail lamp circuit board. They are prone to corrosion.
Old Feb 2, 2009 | 8:40 PM
grejohn's Avatar
Default 97 venture turn signal
my problem is the front left turn signal. I already checked the tail lamp circuit and it's seems okay. is the tail lamp board affects the front signal lamp too??
thanks
Old Feb 3, 2009 | 5:40 AM
dorman68's Avatar
I used to own an 98 Venture. My issue was that the left side turn signal wasn't blinking, it just stayed illuminated. A friend of mine suggested to look at the tail lamp assembly, he stated that the circuit boards corrode. He was right it was corroded. Anything is possible like a turn signal switch or flasher but in my case it was the circuit board
Old Feb 3, 2009 | 4:40 PM
grejohn's Avatar
Before I got this front left turn signal light, I experienced problem in my tail light also and your are right that the board is corroded that caused the problem. I made a jumper to correct the corroded pin. The problem before was when I hit the brake the tail signal light is blinking plus rapid tick on the dashboard. So.. I fixed that problem before by putting the jumper. But now that the problem is the front signal light I want to know if the tail light circuit board has electrical connection with the front.
koobiidoobii
Aug 22, 2022 5:21 PM
RomanGuzi
Oct 2, 2011 11:40 AM
mjpull
Aug 19, 2008 12:20 PM
derrik38
Jun 13, 2007 9:09 AM
derrik38
Jun 4, 2007 10:02 PM
