Venture 1997-2005
Platform: U-Body
2000 Chevy Venture - heater problem
Old Apr 1, 2007 | 7:14 PM
llou's Avatar
Default 2000 Chevy Venture - heater problem
Greetings;
The heater in my 2000 Chevy Venture only works on high (5) but not 1-4.? Any help would be appreciated.
Old Jul 13, 2007 | 2:22 PM
lacelles's Avatar
Default RE: 2000 Chevy Venture - heater problem
I have the same problem on my 98 venture, work on 4 and 5, but not on 1-2-3
Old Aug 11, 2007 | 10:31 PM
goingmyway's Avatar
Our 98 did that too. Had to replace both the resister in the blower box under the glove compartment $65.00 for part and the whole enviromental cluster $250.00 for part. Both were simple replacements but the the resister was a little difficult to reach. Sometimes its just one or the other not usually both from what I hear.
Old Dec 8, 2008 | 7:33 PM
jtruchan's Avatar
Check cabin filter, if it blocked it seems like the heater only works on 5.
Old Dec 9, 2008 | 12:53 PM
shawnvw's Avatar
Banned
wow...talk about digging up old posts....this was posted over a year ago
Old Jan 18, 2009 | 10:24 AM
Tress's Avatar
Default Venture Heater Blowing Cool Air
My 2001 Venture Cabin Heater was week and finally it totally gave up. I have Flushed the cooling system and replaced the Thermostat 3 months ago. Engine temp is steady @ 85 deg. Line goes to Heater is nice and hot comming out of core is cold.
Before I replace the costly heater core I would like to check the pipe piece attached to the head with a priming screw on top. This should be doing the all important coolant flow in and out of the heater core. When take a sharp left turn while driving I get a short blow of nice hot air for for few seconds. could that mean the heater core is not blocked?
Please help me at your earliest as i have to drive in very cold winter in Toronto.
Old Jan 18, 2009 | 12:37 PM
Ernesto71's Avatar
novate Motor temperature must be near or ligthly above 200 Farhenheit degrees, and there must no be air bubbles in the cooling system,_sorry for the syntaxis of my english_, and when you be adding coolant the heater must to be on
Old May 4, 2014 | 11:11 AM
nelsonquilesjr23's Avatar
Default bogging down
Hi, im having a problem with my car. I had a small hand held computer plugged in my car and the code came up P0341 cramshaft positioning sensor.. so I bought a new sensor and I put it in and the car is still doin the same thing...I also put a new fuel pump & filter thinking that it was the problem and its not..so my friend brought me the computer again and its saying the same thing....the cramshaft positioning sensor. ..I also put a new crankshaft sensor....im starting to get really upset cause I dont know what it is....
Old May 5, 2014 | 1:05 AM
sergeimoskva's Avatar
Hi!
in your case code P 0341 says - camshaft position sensor A-bank 1 ckt range/perf.
Most likely you have a loose connection (connector ) or a broken wire.
Baker22
Nov 25, 2014 11:07 PM
spearfishman
Dec 2, 2013 10:38 PM
JediKnight2
Feb 10, 2013 7:51 PM
jramig3
Dec 8, 2008 7:22 PM
rpl47
Jan 6, 2007 2:48 PM
