Venture 1997-2005
Platform: U-Body
2000 Venture Turn Signal Problem
Old Dec 2, 2008 | 12:27 PM
jramig3's Avatar
Default 2000 Venture Turn Signal Problem
I have a 2000 Venture with an interesting turn signal problem. When you step on the brake pedal, both turn indicators in the dash illuminate. If the right-turn signal is active with the brake pedal depressed, it flashes fast like there's a bad light bulb.I did a visual check on the bulbs and they are all working.
Old Dec 8, 2008 | 7:22 PM
jtruchan's Avatar
Default RE: 2000 Venture Turn Signal Problem
Had the exact problem only my was the left turn signal.
I fix mine by looking at the rear tail light assy connector and saw a slightly burned pin and the plastic looked melted. You can replace the connector but I took the assy apart and solder a wire on the ground bus inside the assy and spliced the other end to the ground on the connector wire.I figured I would never have to replaced the rear Tail light assy. If you move the wires around on the connector with the right turn on you might be able to have the lights work correctly. Thats what I did and found the problem. Good Luck
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
snot rocket
Jul 14, 2011 3:15 PM
rogerventure
Apr 17, 2011 6:42 PM
whalen77
Feb 3, 2009 4:40 PM
