Venture 1997-2005
Platform: U-Body
2005 ABS issue
Old Jun 12, 2022 | 3:31 PM
milehigh's Avatar
Default 2005 ABS issue
This seems to be a common problem. 2005 Chevy venture. When stopping (mostly at very low speeds) I get a vibration in the brake pedal. For some reason it's worse when turning. Eventually, I will diagnose the issue (I suspect the sensor wire but would like to hear any other ideas) For now, I just want to disable ABS (never liked it anyway... I'm old school and have been driving for over 45 years) Can't find the ABS fuse (or is it called something else) Instrument panel fuse box or under hood box?
Old Jun 12, 2022 | 3:37 PM
milehigh's Avatar
I recently checked the brakes (I'm an auto mechanic) They looked fine. ABS wires looked good (but I didn't like the close clearance with the CV axle... bad design) I didn't think to do a quick check of the wheel bearings (front) Will do that soon.
Old Jun 12, 2022 | 5:18 PM
milehigh's Avatar
Like I said... doesn't seem to be an ABS fuse (on it's own) It is a fuse that also goes to other things I need.
Here's a video showing this:
Old Jun 12, 2022 | 5:20 PM
milehigh's Avatar
Can I just unplug the controller module? Or another way to disable ABS? I really don't need it.
Old Jun 22, 2022 | 12:39 AM
Photon440's Avatar
When you say "doesn't seem to be an ABS fuse (on it's own)" are you referring to the fuse that also manages the door locks and power mirrors? (#7 at the 3:25 section of your video).
There's also another one bottom right on the video at the 1:40 mark.
If removing a fuse won't do it, unplugging a wheel speed sensor on the brakes should disable the ABS.
GARY STOCKBRIDGE
Sep 22, 2020 7:22 AM
dowdytf
Dec 30, 2018 5:46 PM
05 Silverado
12
Oct 25, 2017 2:15 PM
aiwit
Oct 5, 2011 7:56 AM
mjjv
Aug 12, 2008 11:08 PM
