Venture 1997-2005
Platform: U-Body
'97 Venture LS, No Air Conditioning
Old Jun 28, 2006 | 10:40 PM
tdavetice's Avatar
Default '97 Venture LS, No Air Conditioning
With the engine running, the A/C compressor doesn't engage when I push the A/C button on the dash. The light on the button comes on when it is pushed. The fuse is not blown on the fuse panel.
Any ideas?
Old Jun 29, 2006 | 11:04 AM
Nomad76lj's Avatar
Default RE: '97 Venture LS, No Air Conditioning
cheack the wires to see if they are broken anywhere or use a volt meter at the plug on the compreser to see if its geting any power with the switch on. hope this helpes.
Old Aug 10, 2006 | 9:59 AM
ottawaventure's Avatar
I would have to assume that the freon is probably low. You can take off the sensor at the accumulator and jump it to see if the clutch will pull in.
Old Aug 15, 2007 | 7:06 PM
jdonline
Guest
Posts: n/a
I hadAC issues earlier this summer. I can only imagine how those type of issues could be more problematic later on during the hot months.I would first recommend checking the compressor clutch circuit to see if it's working properly. If that's okay then I would suggest checking thecompressor clutch itself. Good luck.
Old Aug 19, 2007 | 8:06 PM
nprdavid's Avatar
it definately could be the compressor or just low on r134a. check the clutch first for it to be visibly broken and then check the r134a level. If necessary and it is low you could jump the relay to get the compressor to run while you fill.
tubaguy63
Jan 6, 2010 6:47 PM
voma
Jun 22, 2007 1:46 AM
Mother
Dec 27, 2006 9:04 PM
wesandmarlene
Jul 23, 2006 6:34 PM
gener
Jul 14, 2006 10:47 PM
