Venture 1997-2005
Platform: U-Body
airbag sensor replacement
Old Jul 25, 2011 | 8:00 PM
mdjbhouse's Avatar
Default airbag sensor replacement
Just had my 02 Venture in at the garage and one of the issues I reported was the ABS light on the dashboard stays on. Sometimes it will go away but then it comes back again.
My mechanic didn't have the part (frontal airbag sensor) plus is was a couple hundred so I said I'd get back to him and now I also wondering if it is a DIY.
Location is under the passenger seat. Can I start by just cleaning connections?
Old Jul 29, 2011 | 7:22 AM
lexisdad1201's Avatar
It really depends on which sensor and if it has direct connection to the main airbag computer. I would verify what part needs replaced and then unhook the battery and leave it for at least 30 minutes before starting any work. My airbag light does the same thing. It's for the passenger seat belt buckle module. Since the wonderful GM cupholders are right next to it, my guess is soda or something got spilled into the connector. If I tap the buckle receiver a few times and then start the van there is no air bag light. It's only job is to tighten the seat belt by a couple inches in the event of an accident. Your module may be the one that commands your airbag to blow. That would not be something you want to mess with yourself and let a professional do it. It's all safety related and up to you.
Old Aug 3, 2011 | 10:27 PM
mdjbhouse's Avatar
Since I don't really have the details I would agree best not to play with it.
Thanks for the reply.
StellaBlue
Apr 3, 2023 3:17 PM
rnorman4
May 18, 2014 7:06 PM
d0n
Sep 11, 2013 12:00 AM
BigShowJoe
May 25, 2011 8:06 AM
Mcfrey
Nov 5, 2010 12:15 PM
