Venture 1997-2005
Platform: U-Body
Anyone know how to install head gaskets?
Old Jun 5, 2010 | 5:12 PM
Alex from GA's Avatar
Default Anyone know how to install head gaskets?
Losing coolant big time. 40 miles took me 3 hours with me putting water in it every 5 miles. I bought the gasket set but need direction. Thanks.
Old Jun 5, 2010 | 6:19 PM
MDTAHOE's Avatar
Professional Mechanic
If you have never done anything like that before then it is not a job you should do. It is extremely difficult especially with the engine in a van. Also you would really need to buy a service manual to do it because there are very specific torque specs that MUST be used on assembly. You will also need a good quality torque wrench. The job takes at least a minimum of 8 hours start to finish for a good Tech. to do in a shop with all the right tools on hand and air power. Doing it outside at home especially if you do not do that kind of work will most likely take 2-3 days. When you open the hood you pretty much are removing everything you can see.
Old Jun 12, 2010 | 7:07 AM
Thank you for your answer. I'm retired and have plenty of time, tools and air and a son that's a mechanical as I am and more limber. I used to be a motorcycle mechanic and have built many automotive engines, hotrods, etc. I took out a book from the library and copied the pages that were pertinent. We're going to tackle it.
projectman69
Camaro
May 19, 2010 11:58 PM
97RedBull
Mar 4, 2010 8:42 PM
craazyfool
Mar 1, 2010 10:21 PM
craazyfool
Feb 28, 2010 5:08 PM
mjs182004
Oct 17, 2008 11:56 AM
