Venture 1997-2005
Platform: U-Body
Code po742
Old Sep 26, 2011 | 6:27 PM
lilrebel's Avatar
Default Code po742
When i got my 1999 chevy venture van it was shifting really hard so i put some sea foam in and put it on my computer code i got was po742 so i reset comp to get rid of code and that worked till today i was driving it and the light come on again got same code so i reset again and test drove it and light is off and drives fine could someone tell me what could be wrong with it thanks
Old Sep 26, 2011 | 9:48 PM
EinST's Avatar
Transaxle code P0742 says the TCC release switch circuit was closed (indicating the TCC was applied) while the TCC was commanded off. The problem could be electrical like a short in the circuit or mechanical like a faulty TFP valve position switch, sediment in the valve body, faulty TCC mechanism, etc. Check the fluid level if you can and, if not that, take it in for service.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
timT
Nov 21, 2011 10:29 PM
T'boo Ted
Oct 28, 2010 5:15 PM
tshunt01
Feb 19, 2007 12:26 AM
