Venture 1997-2005
Platform: U-Body
Crank no start except with starter fluid after head gasket job
Old Apr 19, 2021 | 5:55 PM
blue04van's Avatar
Default Crank no start except with starter fluid after head gasket job
Hey there I'm really struggling I would appreciate any help.
I replaced the head gasket and intake manifold gaskets on my 3400 motor.
The van has extended cranks before starting and and often will not start unless I give it a shot of ether. Once running it seems fine although a rough idle. During extended cranks I have confirmed to have spark.
  • New coil packs, one was bad.
  • New fuel pressure regulator, the old one was leaking.
  • Fuel pump pressure is about 48 PSI with engine on and running.
  • New spark plugs and wires.
  • I rechecked the injectors, all around 13 ohms and spray when given power. Not the best mist more of a stream but ok.
  • Thoroughly cleaned throttle body and replaced IAC valve.
  • Throttle sensor tests good.
  • Cleaned MAF sensor
  • Crank sensor output appears good.
  • Replaced fuel filter and gas cap
Any direction at this point would be appreciated, I just want the van to start consistently.
Old Apr 24, 2021 | 1:43 AM
Photon440's Avatar
Some similar issues in this thread may add insight: https://chevroletforum.com/forum/ven...t-start-72454/ also https://chevroletforum.com/forum/ven...e-issue-66190/
My own (2001 Venture) rough running engine troubles ended up being the 24X crank sensor.
Old Apr 24, 2021 | 5:59 AM
blue04van's Avatar
I appreciate it, looks like there is a lot to look through.
If I had an oscilloscope maybe I could do a 'real' test of the 24x crank sensor. I used a guide at this site: https://troubleshootmyvehicle.com/gm...crank-sensor-1
At this point I may just swap it out.
Other theory: I replaced the IAC and heard it sort of self adjust on start up. That said, I think they can be manually adjusted? At the least, I just want to check this.
I built a smoke tester and found no intake leaks.
Old Aug 8, 2021 | 11:28 PM
Photon440's Avatar
Did you get to the bottom of this issue? Was it, perhaps, a vacuum leak? Just wondering because I'm doing head gaskets on a Montana and want to be forewarned if something similar ends up happening.
Thanks...
apate1231
28
Jan 20, 2024 4:57 PM
frustratedmike
Jan 22, 2021 6:59 AM
Steve1979
Mar 18, 2018 9:24 AM
Floyd Hutchins
May 6, 2016 2:35 AM
rickgaio
Apr 14, 2013 6:01 PM
