Venture 1997-2005
Platform: U-Body
Faulty Gas Gauge
Old Aug 30, 2007 | 1:05 PM
auz's Avatar
auz
Default Faulty Gas Gauge
The gas gauge on my 2000 Venture is not working correctly, it goes from full, to empty, to inbetween as we travel down the road. Would anyone know what the problem is and any suggestions on how to fix it?
Thanks.
Old Feb 19, 2008 | 10:18 AM
SailorJohn's Avatar
Default RE: Faulty Gas Gauge
I wish I knew. Mine does the same thing. My guess is the fuel level switch but I havent take the time to check it out. I'm assumeing it is in the tank and would be alot of work and mess. I just make sure my wife resets the trip odometer and refills every 270 to 300 miles.
Old Feb 21, 2008 | 7:57 PM
ktm521's Avatar
Fuel level sensor is the problem and yes its in the tank.
Old Mar 13, 2008 | 3:55 PM
auz's Avatar
auz
Thanks for the feedback, I appreciate it.
auz
Old Mar 24, 2008 | 11:28 AM
bdassbowti's Avatar
Mine does the same thing. Sometimes when your sitting still, it will work for a few seconds. I figured the same problem, but wont get fixed until the fuel pump is replaced. Which hopefully will be never.
Old Apr 1, 2008 | 3:01 PM
yari8202's Avatar
Hi, I had the same problem withmy 2000 Ventureand I was told it was the fuel level sending unit and $800.00 to replace. I ordered the part online for $110.00 and my husband and I did the work ourselves. It is pretty easy as my Venture has a plastic gas tank (big) and its held by 4 side to side brackets.It took us 2 hours (as we kept stoping and watching the kids) problem solved! When I inspected the unit that was in the tankI could easily see that one of the metals "teeth" was bent and that is why it was not registering the amount of fuel in the tank.
I now have another problem with my engine light comming on, I had it scanned and I get a code that indicated a small emissions leak detected (or something like that) The guys at the auto parts told me to open and close the gas cap and reset the code, well it was fine for a week and now its back on. I also have the ABS and Trac Message on!! and yes the Air Bag light too [] Any ideas?????
Thanks!
ahearnm
Mar 19, 2023 6:37 PM
black07LTZ
Feb 3, 2020 6:58 PM
Revedd
Dec 9, 2015 12:49 PM
jacee
Nov 14, 2007 10:50 AM
04impala
May 1, 2007 1:55 PM
