Venture 1997-2005
Platform: U-Body
front wheel scraping and clunking
Old Apr 20, 2008 | 10:09 PM
avoyager's Avatar
Default front wheel scraping and clunking
2003 chevy venture, replaced wheel hub 2 weeks ago after it started humming. This fixed the problem. Now getting scraping sound in slow forward (under 10mph), but it disappears as speed increases. No change in scraping sound when brake is applied. Brake pads are good. Now for the stranger part... when I put it in reverse and go very slow, 2-5mph, it sounds like a clunking sound. I'm not driving it. I torqued the wheel hub to 118 ft lbs, but that sure seemed light while using a loaner torque wrench from autozone. I couldn't get over how easy it was to "click" the torque wrench at 118 ft lbs.
Wondering if re-torquing the hub nut using a different torque wrench may be the solution?
Did I ruin this hub if it turns out I ran it for several weeks at too light a setting?
I did not retry the 12/6 oclock push-pull test yet.
Thanks for any advice.
Old Apr 21, 2008 | 9:11 PM
avoyager's Avatar
Default RE: front wheel scraping and clunking
Follow up...
I bought a new torque wrench and checked the torque.
It was way off on the light side.
I torqued to 118 ft lbs which made me nearly put all my weight on it before it clicked.
Wheel spun freely w/no play at 6/12 oclock push/pull.
I re-checked the caliper bolts, pads, and hub bolts...everything nice.
I test drove and all seems great.
I should have listened to my gut when that autozone torque wrench clicked way-to-early.
Chevy_to_the_Levy
Jun 5, 2016 9:35 AM
thejumpsuitman
Sep 21, 2010 10:30 PM
RMWcavalier
Apr 5, 2010 4:42 AM
chadt256
13
Apr 24, 2009 6:05 PM
jessegranat
Sonic (Aveo)
Jan 17, 2007 5:48 PM
