Venture 1997-2005
Platform: U-Body
Only cool from fron vents, why?
Old Apr 24, 2012 | 1:30 PM
Jouko Tiittanen's Avatar
Default Only cool from fron vents, why?
I have an 00 chevy venture that is blowing only cool heat out of the front vents.
Back vents gives war heat...ok
how this can be possible?
I have put in a new thermostat, there is enough "water"
Both hoses on the engine are hot.
Is it blend door actuator, if yes, where is it ?
Where I can find picture of the engine 3.4 L and location and name of the parts?
Old Apr 24, 2012 | 2:15 PM
Tegnus's Avatar
Hi,
Had the same problem, as it turned out to be Head gasket which is common issue for this car...
My suggestion find a shop that have Combustion Leak Tester and will test your car. I found one, that did it for free.
Read more here:
https://chevroletforum.com/forum/ven...problem-46656/
Old Apr 24, 2012 | 3:15 PM
Hi
Head gasket has already changed to this car, but
There are two different kind of main actuators?
Could it be
ACDELCO Part # 1572647 {#52487750}
ACTUATOR,MODE VLV w/FRT & RR HTR & A/C(C34) or A/C MAN CONT(C60); FRT HVAC UNIT
or
CDELCO Part # 1572288 {#16208039}
ACTUATOR,TEMP VLV w/FRT & RR HTR & A/C(C34); ELEC, REAR HVAC UNIT
does anyone know where those are situated?
thanks in advance
Old Apr 24, 2012 | 8:02 PM
The actuators are under the dash. Not exactly sure where under the dash on the Venture, but they are under the dash.
Old Apr 24, 2012 | 11:42 PM
Default Actuators
I try to find them, thanks!
Old Apr 25, 2012 | 7:25 AM
Default Where this actuator could be?
Hi
I found actuator 1572647, it worked well. (gives air from vents)
Where to find right actuator, and where it is?
See:
RockAuto Parts Catalog
Heater Blend Door Actuator
could it be:
ACDELCO Part # 1573627 {Click Info Link for Alternate/OEM Part Numbers}
ACTUATOR,TEMP VLV w/FRT & RR HTR & A/C(C34) or A/C MAN CONT(C60); ELEC, FRT HVAC UNIT
Please if you know, please inform soon, thank you!
Old Jan 2, 2014 | 8:29 PM
huntersdl's Avatar
did you find an answer? my father in law has same issue. We were thinking clogged heater core or the door actuator vent. THe head gasket was just Barely leaking and seems to have stopped with the K&W fiber seal. We think the core is clogged so trying to figure out which hoses to try and flush first before we try replacing that or digging around for the vent
xeqshnr
HHR
22
Feb 13, 2015 9:18 AM
joe in calif
Jul 5, 2012 8:37 AM
Tallguyfl61
Nov 10, 2009 9:38 PM
SILVER DAYTONA
Nov 2, 2009 10:40 AM
