Venture 1997-2005
Platform: U-Body
Power window problem
Old Jul 25, 2007 | 11:40 AM
Luca1's Avatar
Default Power window problem
When I raise the driver side power window, the motor continues to try to raise the window after I remove my finger from the button. The button does not stick. I have to quickly press and release the button to lower the window to stop the motor. It does not happen when I lower the widow. Is there an adjustment or should I just replace the motor now. (So it doesn't die during a torrential downpour when the window is down.)
Thanks
Old Jul 25, 2007 | 11:33 PM
FastGirl's Avatar
Default RE: Power window problem
probably the window regulator it may come with or without the motor.
jen
Old Aug 11, 2007 | 9:25 PM
goingmyway's Avatar
Hi, I think this is by design on the drivers side. Does your drivers window switch have the word "Auto" imprinted? If so you have the feature like our van does called "auto-down" The manual states the drivers window switch has two modes, one is active by pulling up on the switch and one is by pushing down or something like that. Of course yours could be acting radomly if its failing but you might want to check the manual first to see if your van has this feature. I think they put in it for pulling up to tollboths on highways so you did not have to keep one hand off the wheel for too long or something. Makes sense on a soccer mom type vehicle. Let us know what you find out.
mrmark
Astro
12
Jul 25, 2015 11:47 AM
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
guitarplayer
Feb 25, 2008 8:10 PM
