Venture 1997-2005
Platform: U-Body
Rear door won't unlock?
Old Apr 1, 2007 | 3:16 PM
98greenventure's Avatar
Default Rear door won't unlock?
My rear door won't unlock unless I flicker the unlock switch about 100 times, then it does. No, my key doesn't work. Could this be an issue with the rear lock? The handle does stick. Thanks.
Jason
Old Jul 13, 2007 | 2:24 PM
lacelles's Avatar
Default RE: Rear door won't unlock?
I have the same problem on my 98 venture, but now I can't even open the door anymore... keyless entry doesn't work and my key lock is broken...
Old Aug 9, 2007 | 7:41 PM
romeyn's Avatar
Same here. The original problem was that the latch wasn't latching. It was stuck open and the door wouldn't stay shut. Then someone else tried to "fix" it, decided it couldn't be fixed, and managed to get the latch to latch one last time and then shut the door. The handle is totally non-functional now, and using the key doesn't do anything. (This is not my van.)
How can I get the latch to release when the handle doesn't work?
lonemopper
Uplander
Mar 25, 2018 12:35 PM
polpower
Aug 19, 2013 10:42 PM
djfjones619
Jan 30, 2008 12:35 PM
drjimbo
Jun 10, 2007 11:01 PM
