Venture 1997-2005
Platform: U-Body
venture brake problems
Old Dec 18, 2006 | 9:59 AM
preciousbrat's Avatar
Default venture brake problems
I had my boyfriend change my front brake pads yesterday on my 97 venture (they weren't too bad but needed changing) and he decided to bleed the brakes. All was dandy until we started the van back up and lost all brake pressure. We tried several times to bleed the brakes and each time seemed fine til the van was started back up. We even bled them with the van running. I had pressure again until the van was shut off and back on again. Again the brake peddle floored. I wouldn't think the master cylinder would go bad during a simple brake pad change. What could we be doing wrong if anything?
Old Dec 21, 2006 | 8:22 PM
Default RE: venture brake problems
Well, problem fixed. It was indeed the master cylinder. Good thing it went while I wasn't driving.
Old Feb 14, 2007 | 1:13 PM
shnormo's Avatar
You have ABS prolly and of course brake booster. When you are equppied with these, you shouldn't push the pedal all the way down to the floor when you bleed them.
bsco
Aug 22, 2013 4:13 PM
AndrewSE
Mar 13, 2010 12:49 PM
AndrewSE
Jan 7, 2010 8:22 AM
acer33
Jan 4, 2007 6:42 PM
Jonathan93
Aug 8, 2006 4:03 PM
