Platform: Delta
Also Check out CobaltSS.net
restrictor plate
Old Sep 16, 2007 | 4:16 PM
nolanz24's Avatar
Default restrictor plate
i was wondering if anyone knew if the cobalt SS had a restictor plate
its not the supercharged
Old Nov 12, 2007 | 9:29 PM
Red07SSNA's Avatar
Default RE: restrictor plate
Do you mean an intake restrictor plate? I've taken off 2.4L and 2.2L TBs and intake manifolds and have not seen a restrictor plate of any kind. Not in the exhaust either.
The 2.4 uses a 1-piece plastic intake manifold with a 68 MM TB (base opening measurement - not venturi).
The 2.2 uses a 2-piece glued-together intake manifold with a 60 MM TB (base opening measurement - not venturi). The 2.4 intake manifold has larger runners and the TB is centrally located while the 2.2 TB is offset to the drivers side.
staten
Oct 8, 2011 6:38 PM
TRock
Jul 24, 2008 5:35 PM
MWRacing
Feb 14, 2007 11:27 PM
ltzmego
Sep 26, 2006 10:58 PM
y13supio
Jul 4, 2006 7:43 AM
