Notices
Sponsored by: DashLynx
95 5.7 "Cat" removal
Old July 26th, 2012, 8:42 PM
ncsouthpaw's Avatar
Default 95 5.7 "Cat" removal
I have a 95 Silverado with a 5.7 engine, what effect will it have on the running if the Cat is removed. Anything else need to be done to keep the truck running smoth.
Thanks for any advise Ronnie
Old July 27th, 2012, 6:27 AM
shamrock246's Avatar
Not sure you would gain anything unless it was clogged
Old July 27th, 2012, 7:16 AM
ncsouthpaw's Avatar
It's not clogged but it rattles like the material inside is loose.
Old July 28th, 2012, 12:41 AM
66nova's Avatar
It will be louder and that is about it. I ran my 95 without a cat for quite a while then stuck one back on it once I moved to Texas and had to get it inspected. I actually think I got better mileage with it on. I did install a Magnaflow cat from Jegs because it was a ton cheaper than a stock replacement.
Old July 28th, 2012, 8:15 AM
I would replace it before all that crap ends up clogging the muffler it happened to my 83 chevy wagon,how is the 95 setup single in and out?i would check out JEGS also maybe one of the universal types would work
Old July 28th, 2012, 8:48 PM
ncsouthpaw's Avatar
Yes it is a single in and out.
Old August 2nd, 2012, 12:55 AM
Doug Roberts's Avatar
I have a 99 with a 5.3 and was told pb will kill values i want my cat gone
Old August 3rd, 2012, 3:20 AM
Mudd Mutt's Avatar
Taking the cat off will burn up your valves to where your engine will have no compression and no power. You have to have some back pressure. If you have a muffler your fine but without anything it all you'll be buying a new engine in a year
damone
May 8th, 2021 12:36 PM
Platinum
January 16th, 2019 9:53 PM
ericnottelin
July 2nd, 2012 10:03 PM
chevyman323
July 16th, 2010 11:56 AM
mike688
Uplander
January 25th, 2010 12:16 PM
Quick Reply: 95 5.7 "Cat" removal
