Turn signal issues with an '01 Venture
Strange turn signal issues with an '01 Venture. When engaging left turn signal, the rear stop lights--including the hatch-light-- also blink, though not at full current. I've checked bulbs, harnesses, and circuit boards. Harnesses had scarred ground connections--black wire?? Tried a bypass around the harness. No luck.
Not sure where to go from here. Thanks in advance for any help.
The ground side of the lamp sockets are all tied together. An open or significant resistance to the actual ground will cause the turn signal current to flow through the stop lamp, center-mounted lamps, and then onto the ground. I'd think the stop lamp is otherwise inoperative. You'll just have to find a way to provide a good ground on the black wire (run a new wire to a known chassis ground or splice it into another).
EinST & lexisdad1201--
Good, solid directions. This confirms and explains what I've read elsewhere. I just couldn't wrap my head around it. I'll now focus on getting a good ground and report back--in a few days or so.
I appreciate the replies very much. What a terrific resource.
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
