Venture 1997-2005
Platform: U-Body
Turn signal issues with an '01 Venture
Old Apr 7, 2011 | 10:35 PM
rogerventure's Avatar
Default Turn signal issues with an '01 Venture
Strange turn signal issues with an '01 Venture. When engaging left turn signal, the rear stop lights--including the hatch-light-- also blink, though not at full current. I've checked bulbs, harnesses, and circuit boards. Harnesses had scarred ground connections--black wire?? Tried a bypass around the harness. No luck.
Not sure where to go from here. Thanks in advance for any help.
Old Apr 8, 2011 | 11:24 AM
EinST's Avatar
The ground side of the lamp sockets are all tied together. An open or significant resistance to the actual ground will cause the turn signal current to flow through the stop lamp, center-mounted lamps, and then onto the ground. I'd think the stop lamp is otherwise inoperative. You'll just have to find a way to provide a good ground on the black wire (run a new wire to a known chassis ground or splice it into another).
Old Apr 8, 2011 | 3:02 PM
lexisdad1201's Avatar
The issues is too many loads using the 1 ground wire. Replace the burned socket with a new one and it should all work fine. This is a common issue.
Old Apr 9, 2011 | 6:38 AM
EinST & lexisdad1201--
Good, solid directions. This confirms and explains what I've read elsewhere. I just couldn't wrap my head around it. I'll now focus on getting a good ground and report back--in a few days or so.
I appreciate the replies very much. What a terrific resource.
Old Apr 17, 2011 | 6:42 PM
Just haven't had time to work on this since the good replies. Got the lights working well enough to drive safely for now. Need to order parts. Thanks again.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
snot rocket
Jul 14, 2011 3:15 PM
whalen77
Feb 3, 2009 4:40 PM
jramig3
Dec 8, 2008 7:22 PM
