1994 350 won't start
Old Apr 13, 2026 | 2:49 PM
dji's Avatar
dji
Default 1994 350 won't start
It turns over but won't start. Last week it started in my driveway then stalled. Now it only cranks.
It has been running great.
!994 Silverado 350 205,000 miles
What I have noticed and checked/replaced, so far.
The fuel pump runs when I turn on the ignition. I can smell fuel when I crank it.
Replaced the fuel pump on 158,500 on 2/2012. New fuel filter last week.
New Distributor 6/2020 =186,410
Replaced ignition module and spark plugs last week. Distributor cap and rotor look good.
Any ideas on what I should check?
Thanks
Old Apr 14, 2026 | 10:54 AM
The fuel pump may be running but is it delivering the correct fuel pressure? Do a fuel pressure check. I have replaced distributor cap and pickup with off brand parts and very shortly they quit working, so these are 2 things you can check.
Old Apr 14, 2026 | 5:57 PM
dji's Avatar
dji
I don't have a fuel pump tester. I wanted to buy one the 1st time my fuel pump went bad. I could never figure out how to connect them to my fuel line. I still would like to get one. Can 1 person crank the truck and take the reading?
Someone told me Harbor Freight has one ?
The first time I just pour some gas down the throttle body and the truck fired right up. So, I knew it was the pump.
This time I can smell gas in the throttle body, but it doesn't start. I did replace the fuel filter. It was time.
I am not getting a spark. So, I replaced the ignition module. (Auto Zone) Best one they had?? Still no spark. The cap & rotor (MSD) look really good, so I didn't replace them.
I put in a new distributor about 15,000 miles ago. The truck has been running great ever since then. Last week it started right up but stalled after a few minutes.
I haven't been able to get it running since.
I do have compression and the rotor moves when I turn the key.
Thanks for the suggestion.
Old Apr 14, 2026 | 9:10 PM
Rednucleus's Avatar
Check your wiring harness going to the ICM. I have replaced three ICM's in my '93 Sub, every time I could get it to fire pouring fule in the throttle body - pump would prime but injectors were not firing.
Old Apr 15, 2026 | 7:06 PM
dji's Avatar
dji
I will check the ICM wiring harness carefully this time. I need to also check the wirings going to the injectors. They were damaged about 15 years ago and I used some liquid tape to cover the bare wiring.
Thanks
Old Apr 25, 2026 | 9:50 AM
tank1949's Avatar
I had similar problem and replaced parts as you did with no better results. It would run and then would not crank over. I gambled on replacing distributor with an OEM new one from O'Reilly's. I am sure there are many available and cheaper at junk yards.
Old Apr 29, 2026 | 5:43 PM
dji's Avatar
dji
I did get it started at the end of last week. It smoked a lot, but it ran smooth. I had some help. Made it a lot easier. Replaced the wiring connectors to the 2 injectors. Bare wires. Unfortunately, the battery went bad and I haven't had it running since I replaced the battery.
I did replace the distributor with a new one about 15k miles ago. Bad module. I decided to replace the whole distributor then with a new one from Summit.
Thanks
Old May 10, 2026 | 5:25 AM
Jim V's Avatar
Thanks
I had the same issue last last week with a 93. No spark. All else good. Started to replace the ignition control module, distributor cap and rotor button since I was right there and the Ignition coil sinse again, I was right there. When unplugging the pigtail from the pickup coil to the ignition control module , the plastic jacket disintegrated and the contacts were super rusted. Since the new pigtail only comes with a new pickup coil, and I would have to disassemble the distributor to install it, I opted for a new distributor since I was way into the money with these other parts. Anyway, it just made sense. I put the motor at top dead center number one, installed the new distributor and it fired off fine.
Old May 12, 2026 | 4:11 PM
dji's Avatar
dji
My truck has been starting right up for over a week. Original starting problem fixed.
Had a bit of an idle problem this week. When I was in reverse or drive (when stopped) the idle would drop down below 400rpm's sometime stalling.
Disconnected both battery cables for an hour yesterday and now it's better. ECM has reset. Still a little low on the rpm's when in reverse and drive (when stopped) but it's better.
Plan to get a new air filter. Maybe this will help?
Helmethead22
1988 - 1998 (GMT400)
Sep 21, 2021 5:13 PM
RChilds69
Sep 18, 2015 10:36 PM
chignola
Mar 22, 2015 4:22 PM
Chevygirl2445
Jul 16, 2014 12:38 PM
palmi
Aug 16, 2009 12:36 AM
