1994 Z71 Electrical system upgrade
I’m seeking information on sound an electrical system upgrade, I have recently added dual electric cooling fans and led headlights. The fans combined pull 49.5 amps. Since adding them my electrical system has started glitching, I have read about upsizing my alternator and wire size. I’m unsure if there is anything more internal that needs to be updated.
that was the point i was interested in. a 50amp draw on the alternator would be the higher hp drain over the stock system if it was running continuously.
i suggest 5-7 hp when engaged and 2hp when freewheeling for a fan clutch
would an alternator upgrade not be a good solution for that?
it would be a good upgrade as you may need more amp output from the alternator to meet electrical requirements when the fans are running.
there is no free lunch...the more load on the system the more the bigger alt will load the engine. the only sa vings you get r when the fans are off.
