1995 chevy Cheyenne k2500 5.0 low power now
Old Apr 10, 2023 | 10:47 AM
kattlove71's Avatar
Default 1995 chevy Cheyenne k2500 5.0 low power now
Ok got it running and fuel pump working now still losing power but now also runs good for a bit but then acts like it has no go. I press gas and it goes very slow. Help please
Old Apr 10, 2023 | 8:39 PM
oilcanhenry's Avatar
Bad IAC
Bad fuel pump.
Those are my guesses of course..
Old Apr 12, 2023 | 8:50 AM
kattlove71's Avatar
Default Brand new
They are brand new on my truck. How can I check them
Old Apr 13, 2023 | 10:04 PM
Lots of junk is coming from Asia. You can test your fuel pump with a gauge. You also may have a bad fuel regulator.
Old Apr 15, 2023 | 9:45 AM
kattlove71's Avatar
What and were and how is the fuel regulator
Old Apr 16, 2023 | 12:27 AM
Since you have a pre-OBD II Chevy, with the TBI fuel injection, the fuel pressure regulator is located under top of the TBI unit. You'll have to remove the two fuel injectors off to replace it, as it attaches to them. You should be able to see the fuel line attaching to it. Probably need to attain some new gaskets when you do so. It's really very simple to do. Easier then working on lots of carburetors, as I have done.
Old Apr 16, 2023 | 9:16 AM
dpieroni3's Avatar
Is the fuel filter restricted? To check fuel psi there is an adapter that goes in place of the fuel filter and allows you to attach a psi gauge. As I remember fuel psi is 9-13 psi. Hope this is helpful.
Old Apr 20, 2023 | 12:57 PM
kattlove71's Avatar
Checked it and is fine I will look at my tbi. Maybe rebuild again. It is killing my alternator. Can't figure out why. I have had 3 in a yr.?? Help
Old May 27, 2023 | 8:14 AM
kattlove71's Avatar
I was told my fuel pump was fine but I did not think so so I took my bed off again and took out pump and yep the wire was bad inside the tank got a new pump and am putting in today I hope this fixes it. I love my truck but after 2000. To fix everything. It better. Thank u.
find out today.
tank1949
1988 - 1998 (GMT400)
Aug 23, 2018 10:47 AM
1994Suburban2500
Jun 14, 2015 11:45 PM
austink123
Jan 24, 2015 1:04 PM
ogarcia_85
Dec 6, 2009 8:59 PM
mmudd
Dec 29, 2007 8:54 AM
