1997 5.7 build for a k1500 with manual trans
Old Apr 27, 2022 | 9:15 PM
RZA ZAR's Avatar
Default 1997 5.7 build for a k1500 with manual trans
Hello everyone I'm kinda new to the whole engine building thing but I know a decent amount about the basics of engines. I'm trying to build for a off-roader/ daily if I need to drive it to work for some reason. Currently I have the engine pulled out as it had spun bearing#8 and started eating the rear main bearing so I'm rebuilding it right now and wanted to know what a good camshaft would be I've heard the comp cam 305h is decent and I love the way it sounds. I just don't know what all I'll need to be able to install it. Along with what else I'll need to upgrade. Currently the engine is a 1 price rear main and is a 2 bolt main with vortex heads and spider injection. I want to keep it fairly stock so that way I can keep it as reliable as possible.
In short I'm just looking to find out what all I'll need to upgrade to install a new cam and what would be a good cam for my application. Thank you in advance
Old Apr 28, 2022 | 12:46 AM
oilcanhenry's Avatar
Most of us don't get into modifications here, but don't go too far with the cam. It might not pass smog, and it might idle like ****. A relative of mine went too far and the loping at idle was horrible.
Good luck to you, whatever you decide to do!
Exec.Moose
Dec 2, 2018 4:26 PM
75 burner
Aug 18, 2014 1:43 AM
crow15
Jan 1, 2014 3:43 PM
Speedy650
Oct 22, 2009 7:03 AM
