1998 Chevy cheyenne starting problem
Old Feb 21, 2020 | 12:25 AM
Sweetchevy's Avatar
Default 1998 Chevy cheyenne starting problem
Hey yall, I have a 1998 chevy cheyenne k1500 with the 5.0. I am having issues with the truck starting. It seems like the starter is loosing power when it's trying to start. Replaced the starter. Replaced the clutch engagement switch. Replaced the battery. Truck sat for a while and I tried to start it and it started just fine. Let it run for a bit then turned it off and it did the same thing again. The starter is engaging but it's not like a normal wew wew wew wew. It's more like a wee lug wew lug wew lug. Please help me. I'm leaning towards maybe the starter relay but I thought I would ask for some input before I did. Thank you in advance
Old Feb 21, 2020 | 2:58 AM
oilcanhenry's Avatar
My guess is that the new starter is defective. Lots of parts are remanufactured or built overseas these days and QC seems to be missing.
Old Feb 21, 2020 | 8:16 AM
Irish_alley's Avatar
I'm here for the party
doubt its the relay as all it does is kick the bendix out and make the contact for the power. i take it, the truck was doing this before the starter replacement? also check your grounds (as in take them off and clean them) make sure your battery connections are clean and tight. theyre known to have some corrosion or just poor connections.
Old Feb 21, 2020 | 9:18 AM
Little Bear's Avatar
Is the starter properly shimmed? Gear engagement might be too tight, cold start good warm start bad would lead me look there first.
Old Feb 22, 2020 | 3:06 AM
Sweetchevy's Avatar
yes, it doing this is what made me replace the starter in the first place
ironhead1974
Feb 22, 2020 10:03 AM
Billy Chapman
1988 - 1998 (GMT400)
Jan 6, 2019 7:19 PM
brmiami
Sep 11, 2016 11:34 PM
burbandad
Jan 11, 2011 3:30 PM
prism
Sep 26, 2007 11:48 PM
